new member please help
Old Jul 23, 2007 | 12:37 PM
milkdud110's Avatar
milkdud110 is an unknown quantity at this point
Default RE: new member please help
al right i was wrong the temp display has oc on it when you turn it on whats that mean?
i found the part but it says theres two diffrent ones one on the hod latch and on in the console overhead
Old Jul 23, 2007 | 12:48 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
By "oc" displaying what do you mean by that. Does that just display across the screen or is it in small print following the temp read out. If its the small print press the us/metric button to switch ya back to farenheit. Otherwise i wouldnt have the foggiest what that may be if its on the whole display.
Old Jul 23, 2007 | 07:39 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
OC is an acronym to let you know that the ambient temp sensor has an Open Circuit (OC). like Kyle said it's the one on the hood latch support (center of the radiator) disconnect it...get a jumper wire and connect the two terminals of the wiring connector together (short) then turn the key on and it should now read SC for Shorted Circuit...if it does replace the sensor, ANY dealer should easily find this in their parts catalog, it's called an Ambient air temperature sensor. If it doesn't read SC with the terminals shorted together then you do have a wire that is cut in two, or a loose connection at an inline connector in the circuit...let me know the results, and if you need help fixing the circuit I'll dig up a schematic and walk you through it.
Old Jul 23, 2007 | 11:23 PM
milkdud110's Avatar
ok thanks for all the help i will try it tommorow thanks to all and we will see what happens
00jimmy4x4
Aug 25, 2012 09:38 PM
opposedforces
Sep 1, 2011 02:59 PM
1992blazerfullsize
May 24, 2009 01:44 PM
rogggg1020
Nov 11, 2008 08:05 AM
moonshiner500
Headers, Intake, & Exhaust
May 8, 2006 10:30 PM
