New one
Old Jun 20, 2008 | 12:13 AM
lombard's Avatar
lombard is an unknown quantity at this point
Default New one
OK. Pulled my boat to the river for the first time. Everything was good. Stopped off and filled up the gas tank on my boat. When I restarted my '00 4wd 2 door, it idled rough and had the check engine light on. It was too late for me to do anything else, so I got the boat in the water and hauled my trailer home.
Anyway, still had a really rough idle. According to the oil gauge, my oil pressure was fluctuating. Plus, by the time I got home, the truck was emitting a smell that was remarkably like rotten eggs. Rotten eggs makes me think of catalytic converter.
In any case, I'm going to get the parts store to read to code for me. Any ideas for me? Probably need to get this thing working. Hate to ruin my toys because of supporting character failures.
Old Jun 20, 2008 | 06:33 AM
Default RE: New one
If you disconnect and remove one of the upstream O2 sensors, does the idle get better? How was the performance on the trip home? If you have access to a fuel pressure gauge (they aren't too expensive), what is the fuel pressure when you first turn the key on? Does it hold pressure after the fuel pump shuts off?
*Moving to 2nd Gen Tech* - Gen Chat is not the place for tech questions.
Old Jun 20, 2008 | 08:21 AM
lombard's Avatar
Default RE: New one
Thanks for moving this to the right place.
I haven't had a chance to really dig in to this one yet. Guess I'll just have them read the code for me. Hopefully it'll be something easy like an O2 sensor...
Old Jun 20, 2008 | 09:04 AM
Default RE: New one
Even if an O2 sensor is tripping a code, it may not be at fault... Please try the test I mentioned and let us know the results. There are a lot of different things that can happen to cause certain codes and it isn't always just the sensor that the PCM is indicating when it triggers that code.
Old Jun 20, 2008 | 10:27 AM
lombard's Avatar
Default RE: New one
Well, the code was a cylinder 1 misfire. I just changed my plugs, wires, cap, and rotor a few weeks ago. Waiting for the truck to cool down now, then I'm going to check all my work. Could be something as simple as a plug wire pulling free. Keeping my fingers crossed.
If there's nothing wrong there, I'll start some of the other trouble shooting you suggested.
Old Jun 20, 2008 | 10:33 AM
Default RE: New one
I have seen, on numerous occasions, where a wire boot has pushed off of one or more of the terminals on the distributor cap. I always use dielectric grease on these terminals which makes things that much more slick which usually results in them coming off sooner. Now, I use a small screwdriver to 'burp' the air out of the terminal as I slide the boot on. This can make the wires a bit difficult to remove as they sort of vacuum seal themselves on, but they'll stay for sure!
Old Jun 20, 2008 | 11:11 AM
lombard's Avatar
Default RE: New one
Simple fix. Plug wire came off the plug some how...
Now I just have to do some searching to find out how to clear the code. The check engine light is still on.
Old Jun 20, 2008 | 11:35 AM
Default RE: New one
It will clear itself if you just drive it.
cjdavidson10
Mar 29, 2013 11:22 PM
97Beater4WD
Mar 24, 2012 03:46 PM
roadkill
May 15, 2010 07:19 PM
deerboy
Tires and Wheels
Dec 16, 2009 04:33 PM
error_401
Nov 13, 2007 07:55 PM
