new spider wont start after warmup
Old Feb 25, 2010 | 07:42 AM
95fourpointthree's Avatar
95fourpointthree is on a distinguished road
Default new spider wont start after warmup
Just got a new spider in a 95 4.3. It starts fine when cold but after it warms up i have to use starting fluid to start it. No check engine light. Any ideas? It never had any starting issues before.
Old Feb 26, 2010 | 08:30 PM
I can start it without starting fluid now if i turn the key on, let the pump pressurize, then turn the key off, repeat twice, then turn the key all the way to engage the starter and she fires right up. It runs ok at idle but sometimes seems a bit starved for fuel (or maybe getting too much?) if i try to accelerate quickly on the road. Fuel pump? Fuel filter? it has about 160k on it (not bad for a 95) but i have no idea when the fuel filter was last changed. I'm thinking that's my next move. The fuel pressure seems correct although sometimes it will hold and sometimes it will drop to about 20 (with the key on but not running). No leaks noticed on the new spider or feed and return lines.
Old Feb 26, 2010 | 08:50 PM
If it drops more than a few psi, you have a leak somewhere in the system.
blkgagt
22
Jan 3, 2015 07:14 AM
filtalr
Sep 3, 2012 06:10 PM
pitouras
Jan 23, 2009 02:09 PM
tckocher
Jan 15, 2009 08:12 AM
portcqb
May 3, 2008 09:21 PM
