No Brake Lights, No power to Brake Light Switch
Old Apr 15, 2010 | 01:29 PM
SCBlazer96's Avatar
SCBlazer96 is on a distinguished road
Default No Brake Lights, No power to Brake Light Switch
the other day i noticed that both of my brake lights were out on my 96 chevrolet blazer! The parking lights are still working as well as the blinkers! The hazard lights are not working either! I have changed the bulbs. I have also changed the brake switch! I have checked the wiring harness on my trailer hitch and all seems to be in tact! I have recently found that i am not getting power to the fuse for the brakes or the brakes switch! Whats wrong??
Old Apr 15, 2010 | 03:34 PM
*Moving to 2nd Gen Tech* - Please review the description of the section you are intending to post in before posting. Thanks.
Does the third brake light work? If not, the likely cause is a blown STOP HAZ fuse (fuse #1 - 15A) in the fuse box.
Old Apr 16, 2010 | 08:12 PM
SCBlazer96's Avatar
We have checked all the fuses, all are good. Third brake light not working.
Old Apr 16, 2010 | 08:39 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
My first gen did this last summer turned out the wire had a break in it on the way to tails took me a couple days of checking everything before I found the issue. Save yourself some time and put a continuity tester on it just to make sure you do not have a similar problem. Once found it was a simple matter to solder and heat shrink a new wire in place (I didn't trust repairing the old one if it broke once how long before it happened again?)
88Chevy
Jun 21, 2012 11:53 AM
whitezr2blazer
May 26, 2011 01:46 PM
radiorara
Apr 14, 2011 03:04 PM
edavison
Dec 20, 2010 09:55 PM
JediKnight2
Sep 11, 2008 07:58 PM
