No crank, loose coil 2002 blazer help
#21
Well George, Thank you! Your help/procedure was INVALUABLE !!! I got the kink worked out i went back to square one and started tracing wires found a bunch of damaged ones fixed them, then as I am going through the UHFB I discovered the smoking gun one crank fuse had power on one leg but not the other pull it replaced it and guess what she fired at first crank AT THE KEY hasn’t started normally in a month or two now it cranks and starts every time at the key no more start button and it’s all back working properly THANK YOU
George
Cjp p
06-11-2023 01:20 PM
LilC
06-24-2021 03:12 AM
rollinlow96s10
01-18-2017 07:46 PM
