No Heat on Feet
Old Feb 7, 2007 | 08:48 PM
BlazerNooB's Avatar
BlazerNooB is an unknown quantity at this point
Default No Heat on Feet
i have a 2000 blazer ls and i get all kinds of heat on my face but none on my feet. This really sucks when its been 5 degrees and below in iowa for the past 3 weeks any suggestions..
Old Feb 7, 2007 | 10:14 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: No Heat on Feet
Does the air just not come out at the bottom when directed there? Or does it come out elsewhere when you tell it to come out the floor? Does it move to the defrost? Korey.
Old Feb 8, 2007 | 01:15 AM
miller_1787's Avatar
miller_1787 is an unknown quantity at this point
i have the same problem too but it doesn't matter where i have the selector put it always come out on your face and i was wondering what should i check
Old Feb 8, 2007 | 10:21 AM
Kordog's Avatar
I think there is a relearn procedure. I will look at work today. I cannot remember if these are electric actuated or vacuum. If they are vacuum I would say you have a loose/ broken vacuum line. I believe the vacuum line is the one that attaches to the intake at the same place as the PCV valve. I would check there today while I am looking it up today at work. Korey
Old Feb 8, 2007 | 05:09 PM
BlazerNooB's Avatar
then i have it set on feet then no air and when i have it set on face and feet only face it works everywhere else but the feet and my feet get froze...
Old Feb 8, 2007 | 07:49 PM
Kordog's Avatar
I checked today and the mode doors are run by vacuum, and the temp door is by electric actuator. So Miller_1787 you should be checking that vacuum line I mentioned, and let usknow what you find. Blazernoob, I still don't 100% understand. So when you have the mode set to floor you don't have any airflow anywhere?? But works fine on the vent and defrost, right?? I have read about the airdoor/ linkagefor the floor heat breaking. That is what it sounds like to me if I understand you by saying it works fine everywhere but on the feet. If this is the case you will need to remove the dash than the airbox to fix this problem. Good luck, Korey.
vonholt53
Oct 25, 2013 07:01 PM
K-BERTHABABY-5
Feb 8, 2010 09:54 PM
cide
Aug 28, 2009 09:08 AM
hawaiiboi808
Jul 11, 2007 06:29 AM
pophouseman
Jul 23, 2006 05:07 PM
