No heat Please help
Old Dec 26, 2022 | 10:37 PM
bowmantyler's Avatar
bowmantyler is on a distinguished road
Default No heat Please help
The heat stopped working in my 2000 Blazer. Fan blows from vents and floor but no heat and the temp. gauge is barely rising after the engine is warm. How can I fix my heat?
Old Dec 27, 2022 | 12:46 AM
joseywales's Avatar
joseywales is on a distinguished road
possibly you have a failed " fail-safe" thermostat or your gauge is incorrect , usually you will also run rich with a stuck open thermostat such a failsafe unit , grab the heater core hoses at the firewall , both should be about equally as warm , if not you have a classic clogged heater core . backflush if 1 is colder than the other ( usally the outlet or right hose at firewall )
Old Dec 28, 2022 | 06:51 AM
martybgood's Avatar
martybgood is an unknown quantity at this point
Most likely your thermostat is stuck open. I've had my heater core back-flushed numerous times, I finally told them to put the old green antifreeze in it. Never clogged again.
Old Dec 28, 2022 | 02:09 PM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
I too am a believer in the green. One product on the shelf and never had a problem with it.
Old Dec 29, 2022 | 12:00 AM
EricJohn's Avatar
EricJohn is on a distinguished road
Check your heater blower motor resistor.
Old Dec 29, 2022 | 09:31 AM
LannyL81's Avatar
Blower motor resistors are fine as the original poster stated that the fan blows air, just not warm.
Very likely stuck thermostat. Easy to change, a bit messy though. I suggest draining the radiator BEFORE taking the upper radiator hose off the thermostat housing. And of course, only do this on a cold engine.
Careful with the two bolts on the thermostat housing as they screw into the aluminum intake.
bowmantyler
Dec 27, 2022 06:26 PM
reidzap
15
Dec 1, 2010 03:23 AM
Leearchibald
Jan 12, 2010 06:13 PM
zionatdirt
May 23, 2009 02:11 AM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
