No interior lights - no power to the sockets
Old Nov 6, 2020 | 06:09 PM
Rathbone's Avatar
Rathbone is on a distinguished road
Default No interior lights - no power to the sockets
I just bought a 2001 GMC Jimmy. None of the interior lights work. They don't work with the doors open, closed, with the switch on, over-ride off, etc. Also, the bulb was removed from the socket for the under hood light. I tested the light sockets with a test light but there's no power to any of them.
It's possible some previous owner removed the bulb under the hood in an attempt to stop a battery drain problem, but I don't know. There's no power to it, so the circuit was broken somewhere else.
Now that it gets dark early it has really been annoying not having any interior lights. How should I go about troubleshooting this?
Old Nov 6, 2020 | 09:21 PM
LesMyer's Avatar
Hopefully these attachments will get you started.
Old Nov 7, 2020 | 10:20 AM
Did you check the fuse? I would assume you did that first, but you didn't say, so I had to ask.
Old Nov 7, 2020 | 08:38 PM
Rathbone's Avatar
Thanks for the PDFs, I'll read those.
I looked at the fuses, but I don't know specifically which one applies. I don't have the owner's manual.
Old Nov 7, 2020 | 08:43 PM
Rathbone's Avatar
What's an IP Compartment?
Old Nov 7, 2020 | 09:00 PM
LesMyer's Avatar
IP = Instrument Panel. IP fuses are behind a door on the left of the instrument panel. Fuse 8 CTSY LMP. If that is OK then check Courtesy Lamp Relay.
Old Nov 8, 2020 | 10:18 AM
Rathbone's Avatar
Well, now I feel stupid. I didn't notice the fuse panel on the side of the dash. I was looking at the fuses under the hood. The fuse was blown. Replacing it fixed the lights.
Old Nov 8, 2020 | 10:49 AM
Don't beat yourself up over it. We all overlook the obvious once in a while.
Glad you got it fixed. 👍
beaglebronco89
Jul 23, 2014 10:36 AM
seriosbrad
Aug 22, 2013 07:50 PM
nepa zr2
Jan 9, 2013 10:07 PM
kickme005
Aug 20, 2010 08:56 AM
papabears93
Feb 28, 2010 03:41 PM
