no left rear brake light
Old Jul 15, 2011 | 08:11 PM
Chris99's Avatar
Chris99 is on a distinguished road
Default no left rear brake light
I searched thru threads and did not find an exact answer to this symptom.
99 chev trailblazer, no left rear brake light.
The left turn signal works, and hazard works. I compared the lamp filaments to the right rear fixture, so I know which filaments are supposed to work.
I cleaned the sockets with contact cleaner and installed 2 new 3057 lamps.
I wiggled the wire going to each lamp socket, plus wiggled/ moved the entire
housing around to see if I could find an intermitant wire, but no success.
Any suggestions on where the problem might be?
Thks,
Chris99
Old Jul 18, 2011 | 07:23 PM
Chris99's Avatar
Update...
I found the brake light would work, if...... I gently pressed in on the turn signal
lever. Did a further search online and found that multifunction switch is often
the cause of many problems.
I will install a used one tomorrow and report results.
Chris99
Old Jul 19, 2011 | 08:16 PM
Chris99's Avatar
Final update:
Today, I installed a used switch from salvage yard, but that one did not
work any better, had no brake lights at all, returned it.
Called around and found a new one, installed it and now left rear brake light
works, plus other all other functions too.
Now, on to other fixes, vehicle needs a cat, muffler and shocks. I am
considering Bilstein shocks, a magnaflow cat and open to suggestions
on muffler.
Chris99
Old Jul 19, 2011 | 08:19 PM
Glad you got it fixed! I don't know how I missed your post, but I am sorry that no one responded.
nitromt
Aug 6, 2013 07:08 PM
buddanicholson101
Aug 6, 2010 08:49 PM
kiwi
Nov 6, 2009 10:45 PM
calgsblaza
Jun 3, 2008 09:46 PM
Jimonawing
Nov 16, 2007 02:38 AM
