no sparks 96 blazer
Old Jun 4, 2009 | 05:32 PM
COYTOE Z's Avatar
COYTOE Z is an unknown quantity at this point
Default no sparks 96 blazer
ok i put on new coil / wires /plugs / cam module/wires had the icm tested its good /cap and rotor button so what else could there be there is no spark from the coil at all
Old Jun 5, 2009 | 03:03 PM
coolvette01's Avatar
coolvette01 is on a distinguished road
You might check the control module or the hall effects crankshaft sensor in the distributor.
Old Jun 5, 2009 | 03:23 PM
Definitely have a look into the CKP and CMP sensor wiring and output. Connect a multimeter each sensor (one at a time) and read the output as you turn the engine over by hand. If you are not getting any output with the key on, then there is a problem with the circuit.
Try a search for "CKP" and "CMP" for wiring diagrams and pin outs.
FX4DOOR
Jan 20, 2014 11:22 AM
wdhova
Feb 17, 2013 12:49 AM
dothedeww
May 4, 2010 02:23 PM
CEaton
Jan 15, 2009 07:14 AM
pigmak
Jun 22, 2008 02:47 PM
