No turn signals
Old Aug 11, 2011 | 06:24 PM
BeufordRULES's Avatar
BeufordRULES is on a distinguished road
Default No turn signals
Hey all. So my 96 has no turn signals. Also, the dash turn lights both light up when brakes are pressed but nothing when I use the turn signals. All bulbs are lit when the lights are on so nothing appears to be burnt out.
Any help would be greatly appreciated.
Thanks!
Old Aug 12, 2011 | 07:08 PM
Chris99's Avatar
Chris99 is on a distinguished road
Multi function switch may be the culprit.
Do a search on this issue. The switch can be source of many electrical issues.
I had to replace mine recently, as the brake lights would not work unless put slight pressure
on the turn sig lever.
Hope this helps.
Chris99
Old Aug 12, 2011 | 11:57 PM
xgiovannix12's Avatar
Play around with your hazard switch sometimes they like to short out
i say put your blinker on and press the brakes and play around with it like push it forward slightly or backward and see if your lights work right again
if they work again like normal
follow this thread
https://blazerforum.com/forum/tech-a...-repair-29168/
Old Aug 13, 2011 | 11:29 AM
Thx fir the replies.. It was the hazards! Wiggled the button around with the turn signal on and sure enough it came on. Just wedged a screw in there to hold it in place for now.. Thanks for the help!
Old Oct 12, 2011 | 04:04 PM
solaire17's Avatar
solaire17 is on a distinguished road
Xgiovannix12... Hoping you could help me. I have a 97 chevy blazer, 4 dr. My turn signals are not working. My hazards are working. Should I be replacing the multi-function switch? Thank you for your help and time.
Old Feb 18, 2012 | 10:55 PM
tattooed&screwed's Avatar
tattooed&screwed is on a distinguished road
i am having the same problem on my 97 s10 blazer. my hazards work but blinkers won't, which ever i turn on left or right they just stay on and won't blink tried wiggling handle a round then they kinda work and then stop. do i need to replace the eniter turn signal?
Old Feb 19, 2012 | 12:21 AM
Furcritter's Avatar
Furcritter is on a distinguished road
Check your grounds. My '89 Jimmy signals would not work and I had to move the ground for the rear lights due to rust.
Old Feb 20, 2012 | 02:56 PM
it turned out it was my turn signal flasher, solved my blinker problem, cost less than 4 bucks to fix, in case anyone needs to know where your signal flasher and hazard flasher fuse are located they are under the dash behind the knee bolster, behind the cigarette lighter, just a few screws to remove and your there.
Old Mar 9, 2012 | 02:36 PM
ChoochCharlie's Avatar
ChoochCharlie is an unknown quantity at this point
I too lost turn signals. And, it was the flasher.
I lost my turn signals slowly, intermittently. Then they were just gone.
None on the dash. Em flashers worked. Just not the turn signals.
It is located behind the knee panel, below the heater controls on my '96.
I switched the emergency flasher unit to the turn signal spot for the moment. Then picked up a no one for $4 at AutoZone. Changed the heater fan switch too as they had one is stock.
Attached Thumbnails No turn signals-img_20120309_142239.jpg   No turn signals-img_20120309_142231.jpg
SubbinBlazer
May 24, 2013 12:56 PM
BlaZeR FXB1581
Jan 22, 2006 11:51 AM
BlaZeR FXB1581
Sep 2, 2005 07:41 PM
mendez918
Mar 3, 2005 11:42 PM
blazin97
Feb 22, 2005 01:49 AM
