No turn signals
Hey all. So my 96 has no turn signals. Also, the dash turn lights both light up when brakes are pressed but nothing when I use the turn signals. All bulbs are lit when the lights are on so nothing appears to be burnt out.
Any help would be greatly appreciated.
Thanks!
Thanks!
Multi function switch may be the culprit.
Do a search on this issue. The switch can be source of many electrical issues.
I had to replace mine recently, as the brake lights would not work unless put slight pressure
on the turn sig lever.
Hope this helps.
Chris99
Hope this helps.
Chris99
Play around with your hazard switch sometimes they like to short out
i say put your blinker on and press the brakes and play around with it like push it forward slightly or backward and see if your lights work right again
if they work again like normal
follow this thread
https://blazerforum.com/forum/tech-a...-repair-29168/
follow this thread
i am having the same problem on my 97 s10 blazer. my hazards work but blinkers won't, which ever i turn on left or right they just stay on and won't blink tried wiggling handle a round then they kinda work and then stop. do i need to replace the eniter turn signal?
it turned out it was my turn signal flasher, solved my blinker problem, cost less than 4 bucks to fix, in case anyone needs to know where your signal flasher and hazard flasher fuse are located they are under the dash behind the knee bolster, behind the cigarette lighter, just a few screws to remove and your there.
I too lost turn signals. And, it was the flasher.
I lost my turn signals slowly, intermittently. Then they were just gone.
None on the dash. Em flashers worked. Just not the turn signals.
It is located behind the knee panel, below the heater controls on my '96.
I switched the emergency flasher unit to the turn signal spot for the moment. Then picked up a no one for $4 at AutoZone. Changed the heater fan switch too as they had one is stock.
SubbinBlazer
May 24, 2013 12:56 PM
mendez918
Mar 3, 2005 11:42 PM
