not starting with new dist cap rotor
Old Jan 2, 2011 | 04:25 PM
r6thor's Avatar
r6thor is on a distinguished road
Default not starting with new dist cap rotor
2000 zr2 just put in a new distributor cap and rotor i was told that was most likely the cause of an intermittent starting issue. now it won't start any time, and i tested to see if it was a fuel issue with starting fluid and it was not it still would not start. any thoughts on what to check next. and if any one has a photo of the abs block i need to know where the 3 lines run to. i have a manual on order. and i have a computer reader that won't recognize that it is plunged into the jack
thanks
Old Jan 2, 2011 | 05:23 PM
If it won't start with starting fluid, you either have too much fuel (which consequently can also be stated as not enough air) or you have an ignition problem (no or improperly timed spark).
Have you checked for spark?
Old Jan 2, 2011 | 05:26 PM
LannyL81's Avatar
Double and triple check the plug and coil wires at the new cap. Have you tried putting the old parts back in?
Old Jan 5, 2011 | 11:36 AM
r6thor's Avatar
it was just a bad coil some how it stopped working in the time it took me to change the cap and rotor. thanks
LannyL81
14
Mar 4, 2013 05:21 PM
01bluerado
Sep 1, 2011 10:40 AM
scott96
May 26, 2008 09:21 PM
kerander
Feb 11, 2007 06:53 PM
fnirish
Oct 24, 2006 02:02 AM
