O2 sensor
Old Jul 4, 2011 | 10:34 AM
teddybeer21's Avatar
teddybeer21 is an unknown quantity at this point
Default O2 sensor
On my scanner two out of the three o2 sensors the values change rapidly. They are up and down while idling and driving
They are very inconsistent they range from .100 to .800. I'm guessing this isn't normal
Old Jul 4, 2011 | 12:28 PM
Perfectly normal for the upstream sensors to change rapidly. They react to changes in fuel mixture so the ECM can adjust it accordingly. A low reading .1 indicates a lean mixture and a high reading .9 indicates a rich mixture. They should never indicate above .9 volts. The faster they react to mixture changes, the faster the ECM can adjust injector pulse width and provide better fuel economy. Overall, the voltage should average around .450 volts. The downstream sensor monitors catalyst performance only and should remain relatively steady around .4 volts.
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
