O2 sensor removal...
Old May 23, 2007 | 12:05 PM
JoeRock's Avatar
JoeRock is an unknown quantity at this point
Default O2 sensor removal...
I'm trying to squeeze out a little more mpg's on my 98 Blazer. I did all the basic tune-up stuff and the only thing left is the O2 sensors.
I tried today to loosen up the drivers side O2 sensor using a sensor socket and it wouldn't budge. Any tips for lossening it up? It's just me climbing under the truck on my drivewayand I don't have a lift. The workspace for a wrench under there istight.
Would ashop be willing to do a job like this if I supply the sensor and all they have to do is the labor? Any idea of the cost to do this? I'm located in south central new jersey.
Thanks.
Old May 23, 2007 | 02:12 PM
Default RE: O2 sensor removal...
Try heating the sensor bung with a propane torch or if you aren't comfortable with that, just take it for a drive before you go to work. Wear gloves and you should be ok. They should be easier to remove with the exhaust hot.
Old May 24, 2007 | 08:43 PM
geekdagr8's Avatar
geekdagr8 is an unknown quantity at this point
i wanna change my o2 sensors to...what tool do u need to remove them and how many o2 sensors is there?....i see 2 on my exhaust close to the motor 1 on each side...is there anymore then that?.....does anyone know how much they r a piece...just a round about price would be nice....thanks alot
Old May 25, 2007 | 04:42 PM
JoeRock's Avatar
geek,
I've got a 98 blazer and it has three sensors; one on each side of the y pipe (as you mentioned) and one between the cat and muffler. I paid $53 plus shipping at getgmparts.com.
Old May 25, 2007 | 05:15 PM
geekdagr8's Avatar
thanks joe
Old May 25, 2007 | 07:27 PM
As I said earlier in this thread, there is absolutely no reason to change the post-cat sensor unless you have a code specifically stating that there is a problem with it. You will not regain mileage or performance by swapping the rear most sensor.
gdhurst
Mar 25, 2015 01:59 PM
the_Chet
Oct 28, 2010 03:42 PM
GM hater
Jan 9, 2010 02:32 PM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
