OBDII scan tool question
will this tool be good for diagnostic tests capable of testing components on the engine...95 s10 blazer 4x4 4.3L..its on E bay
http://cgi.ebay.com/ebaymotors/ES-SC...lenotsupported
By the look of it it will not read OBD 1.5 as most '95s have so depending on weather you have OBD 1.5 or OBD II will determine whether or not it will work for you
My 95 is OBDII compatible
Where is your ECU/PCM located? If it is on the passenger fender under the hood, then it should be fully OBD2. If it is under the dash and you have the OBD2 plug under the dash, then OBD2 compatible is a funny way of describing it. It is the OBD1.5. A dash of OBD1 and a splash of OBD2, but not fully either.
The ECU/PCM is on the passenger fender under the hood and the plug in is under the driver side dash...Thanks
Before you decide on that scanner, check out www.froogle.com. Enter OBDII Scanner and see what comes up. They have a broad variety of scanners at a broad variety of prices.
Thanks
babeba67
12-02-2013 01:42 PM
swallace8337
10-28-2009 06:50 PM
