odd brake light problem
Old Aug 1, 2009 | 08:22 PM
danjkelly's Avatar
danjkelly is an unknown quantity at this point
Question odd brake light problem
On my 99 Blazer the left brake lights stopped working.
So I figured a bad bulb and replaced it. Nope not it.
Right side works good.
Used a circuit check and no power at socket. Tried to check wiring harness. Seems like right & left are wired separate. One big harness under rear carpet.
Fuses OK
Any idea what to check next??
Thanks
Old Aug 2, 2009 | 05:58 AM
Do your hazards work? Turn signal?
How do the bulb sockets look in the back?
Old Aug 2, 2009 | 09:25 AM
danjkelly's Avatar
Yep hazards work and turn signal. The sockets are the 3057 flat base things, but I don't have power to the brake terminal, when brakes are applied.
It surprises everyone that Left & right turn are fused separately, are brakes lights???
Old Aug 2, 2009 | 01:11 PM
Considering that the brake lights use the exact same bulb filament and circuitry as the turn signals, that is VERY odd...
Old Aug 2, 2009 | 07:47 PM
danjkelly's Avatar
I think the brown wire is turn signal & Yellow is brake.
When the brake petal is pushed only the right side gets power.
Two separate wires come from front of Blazer for the brakes.
I can't see where they start from to check connections
Doggpool
May 24, 2011 08:17 PM
beastbandit92
Aug 13, 2010 08:24 PM
blbikerood
Jan 30, 2010 12:13 PM
myol blue4x4
Oct 3, 2007 09:09 PM
Heffty
Engine & Internal
Mar 12, 2007 04:12 PM
