Oil Cooler Line Preventative Maintenance
Old Jun 10, 2015 | 07:18 AM
masterchf117's Avatar
masterchf117 is on a distinguished road
Default Oil Cooler Line Preventative Maintenance
I have a 2000 Blazer 4x4 that has a bit of an oil leak from the oil pan gasket needing to be replaced. I have cleaned up the area around the pan in hopes that I will be able to see where the leak is coming from without all the dirt and grime under there. I'm pretty confident that the leak is not coming from the oil cooler line, but I was curious if there is any benefit to just replacing the oil cooler lines as preventative maintenance.
Thanks!
Old Jun 10, 2015 | 08:36 AM
burned's Avatar
burned is on a distinguished road
If you have stock oil cooler lines then yes it would be wise to replace.
The factory lines do not last. Build a set of your own so you never have to worry about them again.
These are mine I did 10 years ago and still no leaks.
There are similar how to's on this site if you want to do that.
chipjumper
15
Dec 14, 2019 08:49 AM
joejiz
18
Jan 23, 2013 04:57 PM
ComputerNerdBD
Feb 9, 2010 05:05 PM
goat6500
Feb 2, 2007 02:58 PM
Jetfixer
Jul 11, 2006 05:02 AM
