Oil cooler lines.
Old Dec 17, 2006 | 12:23 PM
splat's Avatar
splat is an unknown quantity at this point
Default Oil cooler lines.
Hi, I just found that my oil cooler lines are leaking. How easy is this job to do? Is there a step by step how to, to replace these lines? Anybody have any advice? I tried searching, but couldn't find and real how-to's.
Or would I just be better off taking it to a mechanic to do?
Thanks in advance.
Old Dec 17, 2006 | 12:43 PM
hillbillyinOhio's Avatar
Default RE: Oil cooler lines.
pretty easy to do. just pop them off. pita to get the clips that hold them into the radiator.
Old Dec 17, 2006 | 01:04 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
with a pair of long nose plyers (if held by pinch clips) its not too bad. But you need to check to make sure its the oil cooler (attached to radiator engine side, other side of radiator if aftermarket) or the oil filter lines (this is the filter relocation setup).
also posting some Vehical info would help too, this is why most put their Vehical in their sig so people know which it is.
Good luck and happy BLAZIN
Old Dec 17, 2006 | 02:37 PM
frankjc's Avatar
frankjc is an unknown quantity at this point
See the post titled "oil leak"
Old Dec 17, 2006 | 09:26 PM
splat's Avatar
Holy cow, I can't believe I forgot to put my vehicle info lol.
It's a 1996 4x42 dr. non-sport model.
I know it's leaking from the back of the engine, kind of by the transmission.
There is no tranny cooler(that I know of), and non-towing package.
Old Dec 17, 2006 | 09:47 PM
MNHawk's Avatar
Check your valve covers (rear) for traces of oil, check around the distributor for the same, then remove the inspection plate for the trany and look up in there. See if there is oil from the back of the motor (would mean rear main seal). Also look around the oil filter (sometimes these will not seat right if the wrong filter or fram filter is used, or then again someone might had loosened it on you)
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
zero psi
Oct 28, 2005 04:45 PM
