Oil cooler lines on '99 Blazer?
Old Jan 31, 2007 | 08:37 PM
cemeteryman's Avatar
cemeteryman is an unknown quantity at this point
Default Oil cooler lines on '99 Blazer?
Just wondering if anyone has experience on changing or fixing the oil cooler lines on a '99 Blazer? Should the lines be replaced or can they be fixed. They are just starting to leak. Thanks in advance.
Old Jan 31, 2007 | 10:18 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Default RE: Oil cooler lines on '99 Blazer?
Are they metal or rubber (probably metal)? Is there rust or rock damage? Unless the leak is at the connector at the ends I would think they need to be replaced. If it's at a connector you may be able to use Teflon tape to stop it.
Old Jan 31, 2007 | 11:38 PM
Thanks fnirish - they are mostly rubber so I probably should replace. I didn't know how hard of a job it would be.
Old Jan 31, 2007 | 11:55 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Yeah just replace them, then do it again very soon. I just replaced mine last summer, and I need to do them again. I hate these lines they just were designed very poorly. Korey.
Old Feb 1, 2007 | 09:48 AM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
I dont think its the lines, it usually isnt. Its usually the rubber o-rings sealing the lines to the oil cooler in the radiator.
Old Feb 1, 2007 | 10:27 AM
Actually, this is usually caused by the poor crimp connections where the flexible lines are connected to the hard lines. Run a search, it has been discussed many times before. If/when mine start leaking on my Bravada, I'll do exactly like we did on my Grandfather's old S10 - Cut the old crimp connections & flex lines out. Braze on -AN fittings to the hard line. Have hydraulic lines made to the proper length to fit.
Old Feb 1, 2007 | 06:16 PM
Thanks for all the replies. I had read about the continual problem of these lines. We'll replace them once, if they start leaking again, approach it differently. Thanks again.
Gearhead52
Nov 7, 2013 02:24 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
cemeteryman
13
Feb 19, 2007 12:55 AM
Jetfixer
Jul 11, 2006 05:02 AM
