Oil cooler lines on '99 Blazer
Old Feb 9, 2007 | 12:14 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Oil cooler lines on '99 Blazer
No, Hanr3 the oil pressure switch does not kill the fuel pump. What the oil pressure switch does is if the relay stops working when the engine is running the oil pressure switch will keep it going. And from looking at the wiring diagrams the newer Blazers do not even has this feature. It seems to be from about '97 and older have this feature only. I also know these will not shut down due to low/ no oil pressure, because I did 2 Blazer motors last month alone from lack of oil pressure, one snapped the crank, the other just about put a rod out the side. Korey
Old Feb 9, 2007 | 01:59 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Yikes, That's good information to know Kordog.
My advice to anyone with leaking oil lines is to change them out asap, Don't put them off.Once they decide to pop (anytime), You won't know about it unless you are staring at your oil pressure guageat that exacttime, or your engine starts knocking. Just my two cents........
Old Feb 19, 2007 | 12:31 AM
Moretorque05's Avatar
Moretorque05 is an unknown quantity at this point
My dealer "offered" to replace my oil cooler lines for $560.... I think I need to find a new dealer....
Old Feb 19, 2007 | 12:55 AM
KLBlazer07's Avatar
KLBlazer07 is an unknown quantity at this point
Yeah, holy that's expensive.
Gearhead52
Nov 7, 2013 02:24 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
cemeteryman
Feb 1, 2007 06:16 PM
Jetfixer
Jul 11, 2006 05:02 AM
