Oil Leak
Old Jan 10, 2012 | 06:54 PM
antman94's Avatar
antman94 is on a distinguished road
Default Oil Leak
Heres the deal, I had a coolant leak so i replaced the Lower intake manifold gasket. During reassembly, I had a dumb a** moment where i read the torque specs wrong and tried to tighten the intake manifold to 35 Ft lbs..... I figured id keep my fingers crossed. Now I see an oil leak occurring. Should I dig in and try to replace the gasket again with the right specs or look towards something else?
Old Jan 10, 2012 | 07:07 PM
Gale's Avatar
Gale is an unknown quantity at this point
Where is the leak coming from?
Old Jan 10, 2012 | 07:55 PM
warthogdriver's Avatar
you may have have squeezed all the sealant out of the back side of the lower intake when you over tightened it...i am guessing you then backed the bolts out to proper torque and created a gap....just my guess.
but hard to tell till you take a look....if it wasnt there before i would say its safe to say recent activity may be connected to it.
Old Jan 10, 2012 | 11:58 PM
antman94's Avatar
right now its coming from a place I cant see so most likely back of engine, its also at the same exact spot underneath where the coolant was leaking.(pic below) As for the manifold itself, I actually didnt realized I over torqued it untill the next morning. I figured I would just try to leave it alone and hope for the best since it didnt leak or anything on the 45 minute drive home. I never had the chance to get the proper torque but it was over torqued by almost 3x the specs.
Old Jan 12, 2012 | 10:57 AM
jaked up's Avatar
jaked up is on a distinguished road
maybe a crank seal and your manifold gasket?
ComputerNerdBD
Mar 20, 2013 12:33 AM
Kaser1026
Dec 30, 2012 05:58 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
