Oil Leak
Old Dec 17, 2006 | 02:35 PM
  #21
frankjc's Avatar
frankjc is an unknown quantity at this point
Default RE: Oil Leak
I replaced my lines this morning. Not too hard to do. I think the hardest part was getting the 10mm bolt back in the bracket. I couldn't really see what I was doing, and I could barely get a ratchet in there. Actually, it was finger tight to begin with. I don't know if someone replaced them before, I got the car in 2002 with 30k on it.
Anyways, it was not too bad, thanks to the help I got here.
Old Dec 21, 2006 | 11:16 AM
  #22
frankjc's Avatar
I am wondering, is there a gasket or oring at the block that I should have changed at the same time? I didn't really look too hard when I was working on it.
Old Dec 21, 2006 | 07:20 PM
  #23
FImports's Avatar
FImports is an unknown quantity at this point
mine are leaking too.im more worried about the oil on my starter.has anyone had that problem before with these lines leaking(oil cooler line)and found oil on the starter
Old Dec 21, 2006 | 11:30 PM
  #24
rooster's Avatar
rooster is an unknown quantity at this point
there should have been a two o ring washer/gasket(kinda looks like a figure 8)that came with the new lines , at least dormans do! if not remove the old one and clean and inspect for cracks or leaks. then replace if ok. and yes these lines always go and always will. kyle came up with an idea on how to replace those lines with hydroulic ones, but i cant remember how. u should pm him(swartlk)
Old Dec 21, 2006 | 11:55 PM
  #25
frankjc's Avatar
I got those gaskets with my new lines. I was wondering if there was something else like maybe an oring at the block.
Old Dec 22, 2006 | 11:38 AM
  #26
rooster's Avatar
negative, just take a dry rag and wipe the excess sludge away from that area. this way u have an even fit..
Old Dec 23, 2006 | 02:39 AM
  #27
Chevy Lover's Avatar
There is an "O" ring on the oil filter adapter at the block, there is also a gasket. There are 2 bolts holding the adapter to the block.
[IMG]local://upfiles/2910/0C5EE692D29441B4AFD1B9CAD88AAB47.gif[/IMG]
Old Jul 5, 2007 | 07:07 PM
  #28
s10machine's Avatar
s10machine is an unknown quantity at this point
91 S10 Blazer 4.3
I am replacing my oil cooling lines, also have a leak at the oil filter mount, so I got a gasket kit, 7-O rings, and 2-flat gaskets, shown in Chevy Lover's attachment. My question is, do I need to use RTV or anything with the gaskets? thanks
ComputerNerdBD
Mar 20, 2013 12:33 AM
Kaser1026
Dec 30, 2012 05:58 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
