Overhead console...
Old Apr 25, 2010 | 04:28 PM
dbark01's Avatar
dbark01 is on a distinguished road
Question Overhead console...
I have a 1996 Blazer LS, the overhead console works but when I turn on temp/direction display it just shows 140F NW, what can I check to correct this? I thought about checking the fuses but if it was a bad fuse the display shouldn't even come on at all...so what else can I check?
I am pretty good with maintenance and knowledgeable in most aspects. I checked the manual in the vehicle it doesn't really get into technical or repair issues.
Any help would be greatly appreciated
Thanks,
David
Attached Thumbnails Overhead console...-blaze1.jpg   Overhead console...-blaze3.jpg
Old Apr 25, 2010 | 05:00 PM
Sounds like your ambient temperature sensor has failed. It is located behind the grill, in front of the radiator.
Old Apr 25, 2010 | 05:19 PM
dbark01's Avatar
Thumbs up
Ok thanks I'll check that out and see what I can find...
Old Apr 25, 2010 | 05:22 PM
I have posted the resistance values for GM temperature sensors before. You should be able to find it by searching for "temperature+resistance" or by CLICKING HERE. The resistance chart should work with all GM temperature sensors.
Old May 3, 2010 | 09:36 AM
dbark01's Avatar
Thumbs up
OK got it, I checked it out and it didn't seem to work right so I went to Autozone and bought a new one for $20 bucks and replaced the old one. Works great now
Thanks!
nelson85
Jun 22, 2006 07:39 PM
DaShark
May 16, 2006 06:13 PM
chevyheavy
May 1, 2006 07:31 PM
cherryred4x4
Apr 2, 2006 12:29 AM
Pugsley
Feb 3, 2006 10:11 PM
