Overhead temp display
The temp display on my overhead console usually shows "--" but every now and then will show some crazy temp for a few seconds or sometimes "OC" when I first start it. Is this the ambiant air temp sensor located behind the grill in front of the radiator?
Well, just got back from the junk yard and for the price of admission ($1) I got three sensors. I didn't have the blazer with me and was going off what I remeber the sensor looking like.
Two of the sensors I got had a single probe sticking out the end of the plug and the third one looked like it had two probes in the plug itself. I knew I had a single probe but I figured what the heck.
The two single probes worked and are only 1 degree off from each other but they are a bit bigger than my stock sensor. The double probe gave me an "OC".
So, for fiddy cents each I got a working OHC temp guage and a spare sensor. I remember a few years back I asked about at the dealership and they said it would cost $40 to do a scan to find out what the problem was and then however much to fix the problem.
Sure am glad this issue came up. I'd completely forgot about it not working as it has been awhile.
They do have a price list but I've found for small items they don't even charge. I've gotten plugs for the headlights free plus a few other small stuff for free. I did find a complete hydroboost brake system out of an Astro van. May go back and see what they'll let that go for.
I have the same situation with a local U-Pull it yard. $1.00 admission and most of the time I am looking for small parts. Either free or under $5.00. My most recent trip was for the plastic skid plate with the Oil Access cover. I found one in good shape. $3.00. I also got two power window switch covers (Passenger/Driver side) for under $5.00.
mritech
Nov 26, 2010 07:53 AM
blackdragon258
Dec 3, 2009 05:37 AM
DaddyCop03
May 11, 2008 09:07 PM
