Haven’t found damaged wiring hanging. Next step is cutting open the wiring thats wrapped so I guess whenever it was first repaired other things may have been prioritized/budgeted
right now using the wiring harness guide to sort through, learn where everything is, should be testing around with my multimeter while I’m doing it i guess
Do understand the function of the sensor and it makes sense with the symptoms. and that the three wires one goes to 12v, ground, and to the computer even though mines different colors got it of rockauto.
about to map it all out over this engine picture cause right now connecting dots is throwing me for a loop
If it was a snake, it would’ve bit me. Mess of wires also found a lose vacuum hose that was blending in with the rest of the noise from the engine
but I got it.
