Parking brake issue
Old Oct 18, 2010 | 12:21 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
Default Parking brake issue
Hi, I have just renewed the parking brake shoes on my 1999 4WD Blazer. It has the "horseshoe" shaped one-piece rear shoes.
I adjusted the cable according to the Haynes manual & now I have a strange problem. When the vehicle is facing downhill the parking brake holds very firmly & will not even move if I put the transmission in drive & try to move forward. However, when the vehicle is facing uphill the parking brake hardly holds at all even at full application of the lever (I have a floor mounted parking brake between the front seats).
Any advice would be appreciated.
Old Oct 19, 2010 | 09:08 AM
blazerpower's Avatar
blazerpower is on a distinguished road
go to a level spot and apply the parking brake and the push on the blazer from both directions and see what happens.
Old Oct 29, 2012 | 09:51 PM
julio's Avatar
julio is on a distinguished road
Default Uphill park/emergency brake issue
I have the same problem and did what you say, same problem when pushing backwards.
Someone told me that my reconstructed brake pads may be lacking an eccentricity to lock itself.
Any advice will be highly appreciated...
Old Oct 30, 2012 | 03:10 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Did you adjust the shoes first then the cable? Or just the cable?
Old Oct 30, 2012 | 07:09 PM
Throw away the Haynes manual unless you need to know how to change the oil! The stuff in them is wrong, missing, or outdated, (they're worthless).
This is straight out of the GM "dealer issue" shop manual:
Disconnect the park cables from the levers at each rear wheel. Adjust each star adjuster until the shoe just barely touches the drum when turning the rotor by hand. Re connect the cables. Loosen the equalizer nut and fully release the park brake pedal. Tighten the equalizer nut until the rear wheels will not rotate, (by hand) without using excessive force, in a forward direction. Loosen the equalizer nut until there is little or no drag when the rear wheels are rotated, (by hand) in a forward direction.
Old Oct 30, 2012 | 11:52 PM
abig84's Avatar
couldnt agree more. everytime i ever looked in one of those books. i either couldnt find, or it didnt have what i was looking for. only use i ever found for them was the electrical diagrams in the back, if they are even right
Old Oct 30, 2012 | 11:57 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Mine holds going forward but not in reverse. Its a 2000
Old Oct 31, 2012 | 02:06 PM
That's pretty much normal on any vehicle, (disc or drum brakes) except the rear disc equipped vehicles that mechanically move the caliper piston out to apply the park brake.
Old Nov 7, 2012 | 09:48 PM
julio's Avatar
Thanks BlackJimmy, we adjusted the shoes first, then the cable, but I think the cable is not tight enough. I'll try to adjust it again and post back
Old Nov 7, 2012 | 09:51 PM
julio's Avatar
Thanks Captain Hook, we pretty much did this but I'll do it again. How do I get this GM "shop manual" that you mention?
Bagherra
Dec 4, 2014 06:48 PM
nineTnine
May 26, 2010 06:44 AM
xderkax
Jan 14, 2010 11:38 PM
blackknight
Feb 8, 2007 03:27 AM
J2K
May 29, 2006 10:50 AM
