passenger window not working
Old Mar 13, 2014 | 08:27 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default passenger window not working
for those of you in the pa nj de area yesterday was gorgeous at a high of 70, i had all 4 windows down and they worked fine. today, if you can believe it, its 23 degrees outside. i kept all windows right at the vent visor levels overnight
i went to go put up all the windows this morning and all went up but the front passenger. i can hear a winding noise when i hit the switch, so im pretty sure it has juice. is it really possible it fell off the track in the course of being park overnight?
and is there a better step than taking the door panel off? im sure theres not lol
Old Mar 13, 2014 | 08:29 AM
newguy's Avatar
Nope, take the panel off, only way to tell
Old Mar 13, 2014 | 08:31 AM
er0ck273's Avatar
that certainly won't be today with the 40mph winds haha.
guess ill head to harbor freight and get some panel/clip removers
i never had a window fall off track. if thats the case, is it simple to put back on?
Old Mar 13, 2014 | 09:36 AM
newguy's Avatar
Never done, changed a window motor. Used duct tape to hold the window up and out of the way
Old Mar 13, 2014 | 09:43 AM
er0ck273's Avatar
right now my window is about an inch down, (i was able to pull it up a little). my window motor and regulator got replaced 2 summers ago. by my once mechanic. so im hoping when i take the panel off the motor is not a clunker
Old Mar 14, 2014 | 03:28 PM
er0ck273's Avatar
got the door panel off, the damn bolts of the motor were at the bottom of the door. remounted that properly
now heres my next problem.
got the door panel back on, all the sudden it doesnt work again...only goes up not down. and this is from passenger switch and driver switch. apparently when you wiggle the blue wire in the cluster at the lock switch on the passenger side is works...couldnt get it out to clean it. bent the pin on the switch towards the contact and we got it to work.
where and what does that blue wire control? and what can i do to tighten it?
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
busta7600
Aug 28, 2012 12:14 PM
Joseph
Jul 17, 2012 04:08 PM
DAGear
Mar 23, 2010 10:10 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
