Passlock
Passlock
After fixing a short in my multi-function switch wires (as seen in this link: https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/headlight-short-43213/ ) My blazer will not stay on!
When I try to start it, it quickly dies out after a quick second.
My security light IS on so I think its the passlock system but it doesnt make since because it does turn on for a little while. I started it with starting fluid and it kept it on for like 5 seconds then it died again.
I have fuel, and i obviously have spark since it turns on.
any idea what it might be?
Oh and I tried to reset the passlock but when i leave it on the on position for ten minutes after trying to crank it, the light still wont go away. And I know your suppose to do it 3 times but from the write up I read the light itself is suppose to turn of after the first time, but mine doesnt. Could anyone relate to my problem? Or maybe help me out to find out what is wrong?
Thanks in advance.
EDIT: I forgot to mention that usually when the truck sits for two or more days it has trouble turning on. It sat for two days but from the previous times it happened before, i dont recall seeing the security light as I do now.
Thanks in advance.
UPDATE: Today I just checked the fuel pressure and I was reading 60 PSI which is good, So i'm guessing it has to be the passlock but I thought if it was the passlock system then it would not let it turn on at all. My truck turns on for about a second then dies out.
hmmm I figured there was something else wrong because on the article you wrote it mentioned it will not turn on, I'm gonna try the the passlock re-learn procedure again.
Thanks for the feedback
Am I doing something wrong?
