PCV valve rattles at idle
Old Mar 13, 2014 | 11:23 PM
Mike F in Nebraska's Avatar
Mike F in Nebraska is on a distinguished road
Default PCV valve rattles at idle
About 2 years ago, I put a new fuel injector spider into my 1998 Blazer. Ever since then, the PCV valve will rattle at idle and at stop signs. The noise drives me crazy. I have tried to put a new PCV valve and it did no good. Other then the noise, the Blazer runs great and has not had a check engine light since. Any ideas on how to get rid of the noise? What could possibly cause this?
Old Mar 13, 2014 | 11:46 PM
richphotos's Avatar
I have known them to make noise usually. are you 100% sure its the PCV?
Old Mar 14, 2014 | 10:43 AM
jimspahr@msn.com's Avatar
Check the PCV hoses to see if there are any leaks or cracks. Look at the grommets, if any, and check for cracks. I would also invest in a AC Delco PCV valve if you used a store brand. The other brands of PCV valves often try to make one size fit too many models and they don't work quite right.
Old Mar 14, 2014 | 09:28 PM
LeWhite's Avatar
As a tune up I replaced the cheap Chinease plastic PCV valve with a new obviously better quality metal one. Guess what?
89Recon
Oct 22, 2011 05:50 PM
Klturi421
Jun 8, 2011 11:39 PM
bnorton4432
Jul 1, 2008 03:49 PM
Resolute
Dec 25, 2007 03:58 PM
blazinloud
Engine & Internal
Sep 14, 2006 12:08 AM
