Please help start my truck
Old Aug 15, 2009 | 06:57 PM
chewie's Avatar
chewie is on a distinguished road
Default Please help start my truck
95 4dr blazer 4.3 vortec
I left my house the other day after the truck was sitting for about 2 hours. When I tried to accel it sputtered, died, and I heard a loud noise coming from the back like it backfired.
I replaced the plugs, wires, cap, and rotor. I'm thinking it is the fuel pressure regulator, but before I replace it I want to make sure there is nothing else I can do to make sure it is that.
I checked the pressure and it holds steady at 60. I can also hear the fuel pump working.
It smells a lot like gas when I'm trying to start it. I'm thinking it is dumping too much gas into it.
I read some of the posts here with the same type of problem and in one someone suggested trying to switch to 2 things in the glove box around.
Should I bother with that or just replace the fuel pressure regulator? I'm inexperienced when it comes to engines, so I don't want to do anything I don't have to.
After I changed the plugs and wires it backfired and literally blew my muffler off Which I had to fix. Then, I replaced the rotor and cap and has'nt backfired again. It just sounds like it is about to start, but doesn't.
Is there anything I can do to check to see if it is indeed the fuel pressure regulator before I spend the money on that and the gasket?
Thanks for your time
Old Aug 15, 2009 | 07:05 PM
Katmandu's Avatar
Katmandu is on a distinguished road
Question
Did the CHECK ENGINE light come on ???
Old Aug 15, 2009 | 07:08 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
first off what are you driving?(make, model, year,etc.)
Old Aug 15, 2009 | 07:14 PM
chewie's Avatar
No check engine light came on.
I will edit my first post. I cannot believe I forgot to put down all the info
bobby099
Dec 22, 2018 09:41 PM
bigdaddykane93
Jan 27, 2016 11:35 PM
Blazinloxtreme
Feb 22, 2013 06:07 PM
jimmy979
Oct 11, 2009 06:28 PM
rogggg1020
Nov 11, 2008 08:05 AM
