Po code help
Old Apr 24, 2023 | 07:41 PM
Xtreme56's Avatar
Xtreme56 is on a distinguished road
Default Po code help
Po code 128 help
Old Apr 25, 2023 | 11:41 AM
GeorgeLG's Avatar
What temperature is your dash gauge reporting?
If you have a scanner with live data, what temperature is the scanner reporting? Is there any freeze frame data with the code?
George
Old Apr 25, 2023 | 01:11 PM
Xtreme56's Avatar
My temp gauge shows about 150 or 160 thanks George
Old Apr 25, 2023 | 03:54 PM
GeorgeLG's Avatar
Here are the proper steps to diagnose:
  1. make sure that the cooling system is full and properly bled
  2. Make sure that the thermostat is good
  3. Jumper the ECT harness signal wire to signal ground with a fused jumper wire and read ECT with a scanner, should read 280F. If not try battery ground.
  4. Test the signal wire and lo ref for shorts, opens, high resistance
  5. Test the ECT sensor
I can help you with any of these steps if you like.
George
Old Apr 25, 2023 | 05:32 PM
Xtreme56's Avatar
Thanks for info I will ck it out this weekend
Old Apr 29, 2023 | 04:58 PM
Xtreme56's Avatar
Default Po code 128
George
I went the easy route l checked my maintenance records and I replaced my thermostat back in 2011 so I just bought a new one and replaced it problem solved normal temperature back to normal thanks for all the help though
Old Apr 29, 2023 | 05:01 PM
GeorgeLG's Avatar
Glad your fixed up
George
joseywales
Oct 14, 2022 08:46 PM
haloboy99
Nov 29, 2011 06:22 PM
b77dougan
Engine & Internal
Jul 27, 2010 06:52 PM
92s10Blzr
Dec 7, 2009 03:12 PM
BABs
Aug 16, 2009 04:35 PM
