Popping Noise (Video)
Old Apr 27, 2011 | 06:54 AM
Darkwolf89's Avatar
Darkwolf89 is on a distinguished road
Default Popping Noise (Video)
Within the past few weeks or so I started noticing a light popping noise coming from the front end of my Blazer. Usually seems to occur when I shift out of park into drive and start moving slowly and turn. I can feel it in the floorboards under my feet. I also noticed a really light rattling feeling too that doesn't happen over bumps or anything I can just feel it from time to time at random times. The popping and rattling I feel are related its just the popping I can isolate and recreate. I recorded a video. The popping happens when I shift into drive or reverse and slowly idle backwards or forwards while turning the wheel. I've also noticed it pulling into parking lots etc. What's this sound? Any help would be appreciated.
YouTube - Blazer Popping Noise?
It happens near the end of the video. I labeled the noises with text so it's obvious.
Old Apr 27, 2011 | 01:48 PM
4goodbuys2's Avatar
4goodbuys2 is on a distinguished road
I have a 1998 bravada that does that same thing when I make slow turns into parking spaces.
It might be the cv axles I plan on changing mine soon to see if that fixes it.
I hope someone has the answer to this because it would help me out to.
Old Apr 27, 2011 | 05:48 PM
rob44_90's Avatar
rob44_90 is on a distinguished road
My inner tie rods are bad and they make a noise just like that. Check tie rods by jacking one wheel off the ground and see if there is any play from left to right. Wheel should not move.
Old May 2, 2011 | 01:42 AM
Darkwolf89's Avatar
I had a smaller shop mechanic look at it that I know personally. He said my passenger side outer tie rod end is shot and everything else seems decent. Why would I feel that under the driver side though? I'm going to take it to my Uncle who works at a Chevy Dealer to fix it (where I don't pay labor) and to make sure there's nothing else wrong. We'll see if they find something else.
Old May 17, 2011 | 04:36 AM
Darkwolf89's Avatar
The Chevy Dealer found one other thing wrong. Turns out along with the Right Front Outer Tie Rod I also had a very worn Idler Arm. Both were changed and everything went back to normal.
hanksta2
Jan 25, 2013 03:57 PM
psyco1887
Suspension Tech
Jun 16, 2006 10:15 PM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
RedBlaze
Suspension Tech
19
Nov 14, 2005 12:36 AM
scoot
Jul 12, 2005 10:57 PM
