Popping noise when turning 97 blazer new cv drive axles
Old Jun 1, 2010 | 01:42 AM
dj00140's Avatar
dj00140 is on a distinguished road
Default Popping noise when turning 97 blazer new cv drive axles
Ok I had a friend replace my cv drive axles in my 97 2-dr blazer 4wd. And its still making a popping noise when turning and turning in reverse. Is it possible he just didn't grease them when he put them in? he said I need a lower ball joint on the drivers side also. Was he supposed to grease them when he put them in? any help is appreciated.
Old Jun 1, 2010 | 06:27 AM
If the whole CV axle was replaced on either side, there would be no greasing involved.
Where did you get the parts from? Were they used or new/reman units?
As a diagnostic step, you could try removing the CV axles completely and turning to see if the noise is still present. This would be a test ONLY. The truck should not be driven except a very short distance at relatively low speeds to test it. Damage to the wheel bearing assemblies could result from prolonged use without the front driveshafts installed
Old Jun 1, 2010 | 12:08 PM
dj00140's Avatar
I dont have the means to remove it again... could it just be the ball joints?
BLAZER97LS
Apr 29, 2012 03:07 AM
roycet4
Sep 21, 2010 07:28 PM
71- Sweet Lucy
Mar 10, 2010 10:42 PM
71- Sweet Lucy
Mar 10, 2010 08:46 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
