is it posible for a/c to cause overheating?
Old May 21, 2010 | 10:04 PM
freightshaker01's Avatar
freightshaker01 is on a distinguished road
Default is it posible for a/c to cause overheating?
i have a 2004 s-10 blazer with a 4.3 ltr. it started overheating so i had the raidator flushed and replaced the thermastat. that fixed the problem so i thought, now it runs at 210 degrees untill i turn on the a/c.after about 20 minutes of running the a/c the temp will go from 210 to 260. if any one has had this problem help would be much appreciated.
Old May 21, 2010 | 11:13 PM
To get cold air inside, heat has to be generated somewhere else.
When was the last time you cleaned the exterior of the radiator and A/C condenser?
Old May 22, 2010 | 02:14 PM
twistedsmily's Avatar
twistedsmily is on a distinguished road
check the fan clutch, mine was doing that same thing,
Old May 22, 2010 | 10:08 PM
R134A's Avatar
R134A is on a distinguished road
Swart and twisted are correct mine did the same thing and the fan clutch fixed it but it is also good to check your condenser and radiator for blockage.
Old May 23, 2010 | 12:36 AM
how can check to see if my fan clutch is bad?
Old May 23, 2010 | 01:07 AM
tlawre87's Avatar
tlawre87 is an unknown quantity at this point
I've tried testing mine two different ways,
1) stick a long piece of heavy cardboard. That should stop the fan.
2) use a water hose, its messy but the pressure should also stop the fan.
tom04841
Jun 26, 2007 11:36 AM
bballer816
Feb 2, 2007 03:40 PM
chevblazer02
Dec 23, 2006 07:39 PM
propellerhead
Dec 19, 2005 03:20 PM
