Possible hood release cable broken
Old Jan 31, 2014 | 06:04 PM
runningoec's Avatar
runningoec is on a distinguished road
Default Possible hood release cable broken
I have a 1997 Blazer. The hood release cable is not being pulled back in to the latch mechanism. I believe that the cable either slipped off or it broke. The cable is still resisting me from pulling too hard though. I need help on how to open my hood manually from outside the car. If you need pictures I can take some to show what is happening.
Old Jan 31, 2014 | 06:27 PM
metalmeltr's Avatar
metalmeltr is on a distinguished road
I would have to go look at mine, but i think you can reach up through the grill with a u joint, socket and an extension. Believe it is a 13mm. First try pushing down on the hood first and having someone pull the handle, when the pull the handle pull up on the hood. These latches get sticky and difficult to release which causes broken cables. I would suggest frequent lubrication
Old Jan 31, 2014 | 08:15 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
tap the hood on the passenger side right corner do it a few times and you hood should bounce open, this is what I have to do every so often
Old Mar 18, 2014 | 02:57 PM
Brent Krause's Avatar
Brent Krause is on a distinguished road
If there is still resistance than most likely the spring that pulls it back is either warn or broken. Same thing happened to mine.
sprbld417
Apr 25, 2011 07:28 PM
DAVE SR
Nov 7, 2010 03:10 PM
tmitbyh
Oct 13, 2009 08:01 AM
blazer4x4
Sep 12, 2007 11:59 AM
Hanr3
Jan 22, 2007 02:30 AM
