Power Locks not working
Old Mar 10, 2009 | 07:06 PM
96chevblazer's Avatar
Default Power Locks not working
My power locks arent working on my 96 blazer, when you hit the unlock button it works fine but when you hit the lock botton it just makes a slight click and doesnt lock. I have a low battey could that be it or is it wired in series and one has come unpluged?
Old Mar 10, 2009 | 08:03 PM
Sounds more like your lock mechanism has just gotten sticky or your lock actuator has gotten weak. It is typical for one direction to actuate easier than the other.
Old Mar 11, 2009 | 06:14 AM
but none of the doors will lock so they are all sticky or is it because one doesnt work none work??
Old Mar 11, 2009 | 07:36 AM
Ok, that does change it a bit. Sounds like the RKE module is not sending out the proper voltage on the lock side of things. I am not sure if the earlier 2nd gens have the same setup as the newer ones, but I believe there is a lock and unlock relay...
Old Mar 24, 2009 | 06:50 PM
a ah i found the problem it was the relay it fried up so im getting a new one for $23. Thanks for the help!!
Old Mar 25, 2009 | 05:07 PM
northlander's Avatar
northlander is on a distinguished road
what was the part number on the relay?
Old Mar 26, 2009 | 02:32 PM
the number is VBA-2016
Old Mar 26, 2009 | 02:45 PM
OE part number 88922752.
Jumpman227
Sep 29, 2012 10:02 PM
crusemm
Apr 6, 2012 09:34 PM
knitter0217
Mar 19, 2012 03:08 PM
Trip..
Nov 16, 2010 02:27 PM
beerguy
Apr 28, 2009 10:12 PM
