Programming mode won't detect FOB(s)
Hey guys! First post here, hope I'm in the right place. I'm in Canada with a '99 Blazer LS, the original OE FOB was slowly dying, (had to press it multiple times and wave it around to get it to work) and eventually it stopped completely. I put a brand new battery in and ... it still didn't work! So I looked a little closer inside and saw the clip that holds the battery in place was a little bent out of shape, repositioned it without disturbing the soldered spots and it held the battery snug.. Still didn't work. Figured, what the hell, maybe I'll try reprogramming it! And... Didn't work!
So today I got a new universal FOB that had great reviews and is specifically made to work with my year and model ( ) and it won't program either!!
I've tried multiple times, and the Blazer gets into program mode easy-peasy, I hold unlock, click-click the key, release unlock, the locks cycle, and I hold down the buttons as per the instructions on this forum (and everywhere else I've looked) and neither the OE FOB or replacement FOB will program.
I'm totally at a loss, every other troubleshooting thread has people who can't get into program mode, or just had dead batteries. I have tried everything in my power, what the hell else could be wrong with it? My key only works in the passenger side lock now, so it's a royal pain in the *** getting in every time.
Thanks in advance for any ideas!
Thanks for the response! Supposedly, the one I got is compatible with P/N 15732805 (OE for 98's-01's) but if there ever was a part number on my OE fob it rubbed off (along with the button labels) a decade ago haha.
[Edit: I cracked open the FOB to check inside as well just in case, but there's no numbers to identify it sadly]
Locksmiths have fob testers that can test your fob functions. I have a local ACE hardware that has one as well. Here's the factory diagnostic info for your 1999.
FYI Keyless entry errors can set "Body codes" that can help with diagnostics. Not very many inexpensive scanners can read body codes. But Car Diagnostic Pro for Android is one of them. Don't know what level you are at, but hopefully this info will help.
Honestly I'm suspecting the BCM could be on it's way out (I do have some weird warning light issues at times) or it could just be a wiring issue somewhere. Hit some nasty ruts and potholes in between the FOB working partially and then not at all, just hadn't considered it til now.
Wish me luck and have a great weekend!
Shauniscool123
01-06-2020 07:00 AM
quick711
02-26-2012 11:29 PM
