questions hopefully someone can help me with
Old Apr 6, 2009 | 09:26 PM
igot10pinitis's Avatar
igot10pinitis is an unknown quantity at this point
Default questions hopefully someone can help me with
ok, had the 97' for 4 days now. Already found a few things wrong with it.
Cab heater fan. When i was going to work this A.M, i turned it on high, it worked well for a few minutes, then i could barely hear it running, the control was still on high. I turned it off and turned it back on, it fixed itself but only a few mins later i could barely hear it again. Went out just a few mins ago to get in it and go, and the fan wouldn't come on period? whats the fix, fan? sensor? ect? How big of a PITA is it going to be to fix?
2nd problem. Flickering lights, when its turned on, the lights flicker both outside and the inside lights. No service engine lights on the car are shown Any suggestions to this?
thanks in advance guys
Old Apr 6, 2009 | 09:30 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
for the flickering lights it could be an alternator i had the same problem a while back and i threw a new one in and took care of the problem.
Old Apr 7, 2009 | 09:07 AM
C.Daniels's Avatar
C.Daniels is on a distinguished road
most likely the switch itself has gone bad...its an infamous thing with chevrolet vehicles. The relay is under the hood and should be easy to replace. good luck let us know!
Old Apr 7, 2009 | 02:52 PM
can you give me anymore info on where its at? I drove it again today, heater started working, then came and went as it wanted to lol.
Old Apr 7, 2009 | 03:27 PM
rriddle3's Avatar
I would not be surprised if the blower motor itself is getting ready to dump. Hope not, they can be a pain to get to. You would have to cut out the covering for it on the firewall.
oktain
Sep 24, 2009 01:52 PM
ghost
Jul 3, 2009 10:19 AM
Numba1Sean
Nov 5, 2008 08:27 AM
2klt
Jul 20, 2008 11:45 PM
mortalum620
Aug 15, 2006 10:44 AM
