Radiator Lower Support / Mount / Isolator / Bushing Help
Old Oct 24, 2012 | 01:45 PM
grantolson87's Avatar
grantolson87 is on a distinguished road
Default Radiator Lower Support / Mount / Isolator / Bushing Help
Hello All,
1999 Blazer 4WD
I had a crack in my radiator so I went to replace it and when I pulled it out there are two isolators/ mounts/ bushings that are rubber and have a small hole that accepts the tab from the bottom of the radiator.
The rubber isolators are shot, I cant even keep the one in its place. My issue is that I cannot find these anywhere. Are they the same as a body mount? Does anybody have a part number for these? I checked out LMC as well as my usual online research to no avail.
I appreciate any help you can give a Blazer newbie (lots of S10's but this is my first Blazer.)
Thanks, Grant.
Old Nov 30, 2019 | 05:18 PM
dbelcourt's Avatar
dbelcourt is on a distinguished road
I know the thread is old but in case someone else ever does a search.
When I replaced the radiator on my 1995, the rubber mount bushing were gone. The parts store wanted $25 a piece to special order them. Although I've seen some online for $5, I needed to finish the job ASAP.
I made my owe using rubber freeze plugs. I think it cost me $12 for two. I drilled out the center so the radiator bottom pin fit. Then I turned down the bottom OD to fit inside the hole of the metal.
I'm attaching pics of a plus and the mount.
christine_208
53
Jul 7, 2022 12:22 AM
Hunter Meloy
Feb 20, 2018 02:20 PM
eaglei22
Aug 12, 2016 07:35 PM
ericthughes
Aug 7, 2010 07:43 AM
BlaZeR FXB1581
Engine & Internal
Oct 13, 2006 01:13 AM
