rag joint change
#21
That is your choice, at somepoint you will need to get an alignment done and at that time you can make sure they center your steering wheel. I was not questioning wheather your current alignment was correct, I was just stating that adjusting the tie rod ends can center your steering wheel.
#23
funny you mention that.... post #10.
#25
EDIT: my ujoint is backwards. I compared it to the Flaming River U Jonit. Started another thread, also replied to this thread regarding pulling the steering wheel. may just order the FR u joint?
I know this is an old thread, sorry. I'm installing an eBay version of the flaming river u joint, everything is fine except the side that is supposed to matchup
To the upper section, are backwards. In other words there's 2 flat sides and 2 rounded sides, I'm going to have to unlock my wheel and turn it a half turn to get the top section to line up. I'm wondering if this happens often or if my $35 eBay version is machined backwards. I locked the wheels straight so it hasn't moved. Do I turn the wheel and install, if so can it be adjusted completely with tiered? Would think steering to one side would be ****ty if I did that.....I'll take a pic showing what I mean about it backwards....I've already cut down ny shaft and I have to get it on tonight for wife tomorrow.
Yes it fits 1st gens
Flaming River FR1746DD Billet Universal Joint S10 Blazer ZR2
They are pricy but worth it...I Plan on doing this someday
Edit: Ive seen cheaper.
#26
EDIT: Found some info on S10planet. Splines won't let me move the wheel. Will have to buy the flaming river u joint. Hopefully I dont' have to eat the cost of this one. They said they would take it back, but probably don't know it's been installed....
Do you have any info on pulling the steering wheel? I did the flaming river u joint mod and the ujoint I got has the DD side opposite than the FR version and I need to pull my wheel to correct the 1/4 turn it is off now? Thx
josemateos
02-18-2014 10:00 AM
Guntheone
12-04-2010 05:59 PM
livinterror
12-28-2008 09:50 PM
88blackzcand95blazer
12-19-2008 08:13 PM
hoagmaster
02-01-2008 02:50 AM
