Raising front end
Raising front end
I installed an extra leaf spring to each side of the rear of my 95 due to the heavy cargo I carry, It raised the rear about 2 inches with it loaded, is it possible to raise the front end with the torsions bars, I only want to go about 1 inch in front?
RE: Raising front end
Yes, the TB's can do that. Raising it an inch should not put you into the danger zone on component wear, but I don't think going over that would be a good idea.
Thanks, I just replaced the front end so I think it would be a good time to do it.
I raised it 1 1/2" to sit even with the rear, it handles good and sits just a little higher than stock, I used "add a leaf" in the rear for $65 bucks and installed it in about an hour in the drivewaywith two small jacks, 1 on the frame and 1 on the dif., it isway better hauling a load now! Thanks!
how exactly do you go about raising your front end torsion bars? i have a 1995 S10 4x4 and i would like to raise the front about 1 " but i do not know how to do it. can you explain?
thanks so much for any help
check out the DIY section there is a How-To with pics included.
gtmccormick
04-24-2015 07:29 AM
