My grandmother recently gave me her 99 blazer that I've been trying to get for years. It has had a turn up. I keep getting code p0300. It has a light pop at idle and almost stalls after reving it. I look at the fuel trims with my scan tool and it doesn't look right
We need short term trims, both banks as well. Get all four values at idle and again at 2500 rpm. Yes those numbers are a problem but lets get all 8 before we proceed but adding fuel usually means:
Injector issues
vacuum leak
Intake leak after the MAF sensor
Exhaust leak
Popping/backfiring is usually a timing issue. What is your CMP retard?
I change the distributor. New reading also fuel pre jumps to 60 then to 50 and leaks down to 40 within 8 seconds and keeps dropping. Also is the maf supposed to be giving a reading with the key on and engine not running
