RE; Air Noise
Old Apr 17, 2010 | 06:12 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Smile RE; Air Noise
at highway speeds i am hearing loud air noises on the driver's side window on top. i put my hand by the weatherstripping applying a little pressure and the noise lessens. when i look at the weatherstriipping she looks good and solid.
any suggestions or have you experienced the same.
Old Apr 17, 2010 | 02:20 PM
1998MSO's Avatar
1998MSO is on a distinguished road
What year, model etc....? I had a similar issue with my 98. The door hinge pins caused the door to sag slightly. Worn hinge pins and bushings seem to be a common issue.
Old Apr 17, 2010 | 04:12 PM
Smile RE; Air Noise
she is a 2002 4 door blazer
Thanks.................................
Old Apr 17, 2010 | 06:09 PM
ff_holt1's Avatar
ff_holt1 is on a distinguished road
my 99 makes that noise to i just never really looked to see what was causing it...
Old Apr 17, 2010 | 11:31 PM
Most likely cause is failed hinge bushings.
When you close your door, does the door jump up as it latches onto the nader bolt (latch pin in the 'B' post)? Is the top of the nader bolt scored or worn?
Old Apr 18, 2010 | 05:57 AM
Cool Re Air Noise
I will ask my buddy to check it out.
Old Apr 18, 2010 | 07:43 AM
KRUSHER's Avatar
KRUSHER is on a distinguished road
My 2001 does the same thing. It needs door bushings as well. My door got to making noise when it shut and I discovered this crack:
Luckily I got a buddy at work to TIG weld it back up for me.
moboys
Aug 1, 2011 08:26 PM
nuwave
Feb 10, 2011 01:28 PM
jojocarreno
Jul 1, 2010 07:30 PM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
