Rear end gears
Old Mar 13, 2013 | 09:04 PM
justinh4578's Avatar
justinh4578 is on a distinguished road
Default Rear end gears
1996 4door 4.3 4x4 148k miles
Driving down the road at about 20mph. BAM!!!! Rear end explodes. I limp it about a mile home. Take cover off and chunks fall out. Appears to be just ring and pinion. It just had the pinion seal replaced. I'm guessing the shop didn't torque the pinion back down considering it was less than 30 miles ago.
So what's my next step? Ill call dealer and give my vin so I know what my gears are. Unless they are all the same or something. Banging my head off the wall. Kinda depressed. What else should I look for as far as damage? Is this typical or possible linked to the pinion seal replacement?
Old Mar 13, 2013 | 09:11 PM
Talk to the place that replaced the seal. Quite possible the pinion nut was over or under torqued. If that's the case, they should take care of it.
Old Mar 13, 2013 | 09:27 PM
Thanks. I called them. I told them about pinion but being torqued incorrectly. They basically don't care.
Old Mar 13, 2013 | 09:34 PM
Does your State have a BAR, (Bureau of Automotive Regulation)? If so, you might give them a call, either that or an attorney. You might have to have it looked at by another shop to confirm the problem and possible cause.
EDIT: Before the pinion nut is loosened, rolling torque must be checked. When the nut is reinstalled it must be tightened to achieve the same rolling torque. If it's too loose, the pinion shaft will wobble around and destroy the pinion bearing and then the ring gear. If it's too tight, it will also destroy the pinion bearing and the pinion gear will eat the ring gear.
Old Mar 13, 2013 | 11:11 PM
I live in CA so I am sure we have something like the BAR
The description you posted sounds like exactly what happened. I mentioned that to him and he laughed at me and said his guys don't make those mistakes. But either way I'm calling tomorrow and telling him they need to fix it. From what I've read the spider gears would have gone if pinion was not the issues.
Also the part about the pinion nut, is that a quote from a manual or just your accurate description?
Old Mar 14, 2013 | 11:59 AM
Check with your secretary of State office, they can tell you what steps you need to take.
It is paraphrased from the GM shop manual. That is the procedure whenever the pinion nut is removed. It guarantees that preload is back where it was before disassembly to prevent what happened to yours. Another option is replace the crush washer and set up the differential from "scratch", (far more time consuming). You are correct about the side gears and side bearings.
Old Mar 21, 2013 | 02:10 PM
Well the shop has had my blazer since last Thursday. They said they would fix it at their cost. They are replacing the entire rearend. Apparently California is fresh out if these rears and they had to get one from Oregon. Waiting for it to arrive and install
Old Mar 21, 2013 | 02:56 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
sounds like that shop guy is a douche and when theyre done id just leave and not pay, they owe u that cause they are the ones who messed it up. if they did their job and didnt make that mistake u wouldnt be in this situation.
Old Mar 21, 2013 | 03:11 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
As bright as an idea that is the shop is going to have his keys an address.They may not give him is keys back if he trys to walk out without paying.I agree the shop are the ones who screwed up and the owner of the vehicle shouldnt have to pay a dime.
I delt with a very similair issue some years back.The exact samething happened.The ring gear pin nut wasnt tightened all the way and it came out going into the gears of the rear end causing it to explode.Unfortunately I could not get the shop to pay for a new one.I ended up replacing the rearend myself out of my pocket.
Old Mar 21, 2013 | 04:27 PM
El_Beautor's Avatar
Well I'm glad they're fixing it and paying for it. Hope it all goes smoothly for you.
James1965
Jan 16, 2012 11:32 AM
gumpy69
Nov 4, 2010 07:57 PM
blazerbro84
Sep 24, 2010 06:57 PM
Always Broke
Sep 18, 2010 11:59 AM
Blazin_1t_up
Sep 11, 2008 10:51 PM
