rear end gears!!!!
Old Sep 11, 2008 | 09:52 PM
Blazin_1t_up's Avatar
Blazin_1t_up is an unknown quantity at this point
Default rear end gears!!!!
wat size gears are in the rear end... and wat gear would i need to put in it when i get bigger tires....
Old Sep 11, 2008 | 10:38 PM
mdehoogh's Avatar
Default RE: rear end gears!!!!
Check the RPO sticker on the inside of your glovebox for one of the following codes. The different gearing options varied with different options that came on your truck. There wasn't just one set size that came on all Blazers/Jimmys
GU4= 3.08 Ratio
GU6= 3.42 Ratio
GT4= 3.73 Ratio
GT5= 4.10 Ratio
Old Sep 11, 2008 | 10:50 PM
WolfPack's Avatar
And as far as what you need for your new tires, that's dependent on how big you go. 4.10s would be great for a 33
Old Sep 11, 2008 | 10:51 PM
oh ok ill give it a look
James1965
Jan 16, 2012 11:32 AM
Kemper9388
Aug 24, 2011 11:03 PM
gumpy69
Nov 4, 2010 07:57 PM
blazerbro84
Sep 24, 2010 06:57 PM
Always Broke
Sep 18, 2010 11:59 AM
