New rear end gears and speedometer
Old Sep 11, 2010 | 12:40 PM
Always Broke's Avatar
Always Broke is an unknown quantity at this point
Default New rear end gears and speedometer
Just had new axle and 373 gears put in my 96 blazer and speedo is off of course. Question is do you reprogram the computer or do you replace a sensor to show the correct speed?
Thanks
Old Sep 11, 2010 | 07:02 PM
TripleBlackBlazer's Avatar
The VSS is the same part no matter that gearing. This has to be reprogrammed in the PCM.
What gears did you originally have installed? 4wd? Did you get the 3.73s out of a Bravada, ZR2, or? How much did you pay for the diff(s)? Did you swap them out yourself or pay a shop? How much did the shop charge you if you went that route?
Old Sep 18, 2010 | 11:59 AM
They were 3.42's. The 3.73 posi came from a camaro and i had a good friend and fellow racer put them in at his shop so was not much at all to do it.
Jordan Baxter
Mar 9, 2012 10:14 PM
James1965
Jan 16, 2012 11:32 AM
gumpy69
Nov 4, 2010 07:57 PM
blazerbro84
Sep 24, 2010 06:57 PM
Blazin_1t_up
Sep 11, 2008 10:51 PM
