rear windshield fluid pump mystery
Old May 7, 2013 | 11:19 AM
hunter05's Avatar
hunter05 is on a distinguished road
Originally Posted by missmyK5
I know this thread is old but I had the same problem. The pump would turn but only sometimes and it was too slow to push fluid to the back.First I pulled the pump and put jumpers on the posts to check if pump was working. It was good. Them put test light on plug and noticed the light was weak and sometimes didn't come on. Then I took the switch out of the dash and opened it up. There are two small contacts inside. One each for the wiper and the washer. I cleaned both with the end of a screw driver. Works good now.
You were exactly right. I grabbed a new, used, one at the local pull n save. It works great. My son has had a clear rear window for 2 winters. thanks
Old May 7, 2013 | 03:29 PM
dman001948's Avatar
dman001948 is an unknown quantity at this point
Both of my pumps (Front and Back) are in the fluid Res under the hood. The thing you put blue water in. Its a lot longer then it looks. Once you pull it out you will see both pumps, just replace the one you need to and check your lines to make sure they aren't all dried out and leaking.
joshua_andrew92
Mar 18, 2010 03:01 PM
Matty Kling
Oct 10, 2007 01:25 PM
carlo
Jan 1, 2007 03:03 PM
jboy76
Jun 7, 2006 09:25 PM
kaindragoon36
Mar 25, 2006 04:22 PM
