Relearn after new crank sensor
Old Jun 14, 2018 | 09:12 AM
Tommer2's Avatar
Tommer2 is on a distinguished road
Default Relearn after new crank sensor
Hi Guys. Putting in a new crank sensor. I think I need to have a relearn after installing it. My question is will it run well enough to get it to a shop? Thanks.
Old Jun 14, 2018 | 10:22 AM
Zenith's Avatar
Zenith is on a distinguished road
I just did mine last month along with a new distributor, and it ran fine. Remember the computer adjusts the timing on these engines, so if it starts you should be good.
Check around for prices, the shops in my area wanted $200+ to do a crank sensor relearn and setting the camshaft sensor retard, I found an independent mechanic on craigslist that did everything including live diagnostics for $50.
BTW, my timing was out 22 degrees due to the new distributor (cam sensor alignment) and he set everything perfectly while I watched. He did have to notch the distributor hold down clamp.
Old Jun 14, 2018 | 01:25 PM
LesMyer's Avatar
yes but SES light may be on and/or flashing.
Matt Evan Cinquini
Feb 11, 2019 11:01 AM
Mr. Joe
Apr 13, 2018 02:34 AM
BILL RYBICKI
Sep 17, 2013 02:25 PM
CRDuncan
Dec 7, 2010 06:33 AM
GM hater
Jan 9, 2010 02:32 PM
