Removing Front Caliper
Old May 2, 2011 | 03:49 PM
DoubleSh0t's Avatar
DoubleSh0t is on a distinguished road
Default Removing Front Caliper
Hey all, I've done brake pad replacements 100 times, just not on this truck. I cannot get the right front caliper off. I removed the top and bottom 18mm bolts. It was still on pretty snug, so I used a screwdriver as a wedge (gently) to get the caliper loose. The entire caliper is free, but 'something' is holding it on and not allowing it to clear the rotor. It almost seems like the brake line is too short to allow the caliper to come off. I would remove the line, but it seems unnecessary and I don't feel like bleeding the brakes. I feel like I am missing something obvious.
Blazer is a 2003 4x4. Any help would be appreciated. I'm banging my head against the wall. Brakes shouldn't take 2 hours for one side.
Old May 2, 2011 | 04:15 PM
rodono's Avatar
rodono is on a distinguished road
i think you took the wrong bolts out the bolts holding the caliper on are allen head.
Old May 2, 2011 | 04:26 PM
DoubleSh0t's Avatar
The caliper is free and moving, but it won't come off. See these pictures... These are the dual pistons so I don't think they have the allen screws.
Old May 2, 2011 | 05:20 PM
LRV31's Avatar
LRV31 is on a distinguished road
Can't tell from the pictures but it looks llike your pads have the anti-squeak shim plates on them. If so, pry these away from the pad and pull them off with pliers. That little bit of extra room helped me remove the calipers on my 2000 Blazer just this weekend. Good Luck.
Old May 2, 2011 | 06:20 PM
TouringMike's Avatar
TouringMike is on a distinguished road
By the top pic, it looks like he's got a severly worn rotor, and there's a lip holding the pads in. The OP will probably have to release the pressure on the bleeder in order to compress the pistons in order to clear the lip on the rotor.
Old May 2, 2011 | 09:51 PM
wild bill's Avatar
wild bill is on a distinguished road
When I did mine that little pin on the back of the brake pad was getting caught on the brake piston. Had to loosen the bleeder screw then pry the piston in more.
Old May 2, 2011 | 11:17 PM
TMM217's Avatar
TMM217 is on a distinguished road
Try removing the caliper bracket and remove caliper and bracket as one. The bracket has to come off neways to get rotor off to resurface it. I would pry caliper/bracket off with pry bar/screwdriver. I bet you have a bad rust lip on that rotor thats holding on to the pads. Just pry it off.
Old May 3, 2011 | 06:19 PM
DoubleSh0t's Avatar
I was able to get them off, finally. Thanks for the advice. I called a GM mechanic that I know. He was able to get the screw driver in there as a wedge. Using gradual pressure, we were able to get the pistons pushed back in to place which freed up the caliper completely.
Rotors are still okay for now, but I'm replacing them next time I do pads.
Old May 3, 2011 | 06:53 PM
racsan's Avatar
racsan is on a distinguished road
i always use a big "C" clamp to push the caliper piston back into the caliper bore before removing them. i did have a allen retaining bolt broke off in the knuckle. got it out by using a small cuttoff wheel then heating the knuckle with a torch, then used vise-grips to unscrew the stud out of the knuckle.
duckland23
May 1, 2014 03:04 PM
tommy3678
Nov 14, 2010 06:05 PM
racsan
Aug 12, 2010 01:39 AM
carterx
Apr 17, 2010 06:55 AM
Bob_55
Mar 29, 2010 11:32 AM
